Can a fuse prevent electrical fires? How?
  • Power Distribution IEC
  • Can a fuse prevent electrical fires? How?
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Posted: ‎2021-07-05 05:07 AM
1945
I’d like to know if a fuse can prevent electrical fires into a cabinet.
If yes, how does it works?
Thanks for your feedbacks.
  • Products
  • Safety - Electrical Fire Prevention
RHH
Commander | EcoXpert Master RHH Commander | EcoXpert Master
Posted: ‎2021-07-05 05:20 AM . Last Modified: ‎2022-10-19 01:35 AM
Hey @Teflot,
On its own fuses do not prevent electrical fires.
An fuse stops delivering current when it breaks / melts due to overcurrent (too much)
This overflow can ofcourse be generated by something broken that can cause an fire, but that could (in some cases) already happen before the fuse cuts out.
Here are some explanations how a fuse works and what it does;
https://www.bbc.co.uk/bitesize/guides/zshyj6f/revision/3
And even an nice animated video here, (first part is about the fuse);
https://www.youtube.com/watch?v=HqPHoXRwX5E
EDIT:
An component that can help prevent electrical fires can be found here on this forum;
https://community.se.com/t5/Power-Distribution-and-Digital/How-PowerLogic-HeatTag-helps-companies-en...
Hope this is of any help!
Kind regards,
Rick
RHH
Hey @Teflot,
EDIT:
Kind regards,
Rick
Gregoire_Brun
Commander
Posted: ‎2021-07-06 12:28 AM . Last Modified: ‎2021-07-06 12:36 AM
Hello, ELCB products or modules (VigiPacT offer) could be a solution to prevent fire inside pannel too.
Vigirex -VigiPacT Catalogue
Gregoire Brun
Breaker Product Expert
