Can I configure what info will be shown in a single diagram ?
  • Power Distribution IEC
  • Can I configure what info will be shown in a single diagram ?
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Posted: ‎2022-08-25 04:26 PM . Last Modified: ‎2024-11-22 04:25 AM
1301
Hello
I m new to this software and I would like to ask if I can change the kind of info will be shown in the single diagram.  I m studying a project and I m going to give some single diagrams to the electricians created in Ecodial but i would like for example in cables (or in busbar) to show the Ib current, the Iz current, the short circuit in the bars etc. However I saw that I cannot configure what info will be presented. There are only preconfigured label tags at "Calc Results" and "Solution" tabs which cannot be changed. Is there any way to edit the labels ?
Moreover since in practice noone uses this way of presentation of cables for example, it would be nice in a future update to use another form,  like for example :
5G6 mm2 for multicore
4x(1x6)+1G6 mm2 for single core
this is a better way for practical electricians to distinguish if a cable is a multicore or a single core.
  • Power Distribution Software
Genghiz
Captain
Posted: ‎2022-08-29 12:02 AM
1287
Hello George,
Thanks for reaching the ‘EcoStruxure Power Design Forum.’
Our Comments:
The customization of the parameters; over the single line diagram is not available at the EcoStruxure Power Design – Ecodial.
If this is a most useful feature; then we will keep it informed to the business requirement management to track and prioritize the same.
Thanks & regards,
Team – Ecodial Expert Support.
Genghiz
Captain
1288
Hello George,
Our Comments:
Thanks & regards,
Posted: ‎2022-09-02 08:12 AM
In response to Genghiz
Thank you for the fast response
I guess it would be nice to have the chance to configure the info we would like to see in a single diagram because many of us we use this software to create single diagrams and give them to contractors or electricians to built them. So it would be nice the software to follow the common practice in labeling so everyone to understand.  For example (in cables as I said before) it would be nice to have the form that is used worldwide like  5G6 mm2  or 5x6 mm2 (for multicore) or 4x(1x6)+6G for single core cables.
Moreover what someone need to see in a final diagram in cables' label (for example)  is the cross section of cable (single or multicore) the drop voltage, Ib and Iz and the length.  These info, as I can see, cannot be presented in one single diagram all together.
Something like this :
Cable / circuit name
5x16 mm2
Ib=52A
Iz=73A
dV=0.6%
L= 21m
I hope in a future version to have the option for custom label configuration
