Cable Selection types
  • Power Distribution IEC
  • Cable Selection types
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Husam-89
Husam-89
Cadet
Posted: ‎2022-06-16 12:15 AM . Last Modified: ‎2022-06-16 10:42 PM
1989
Hello Guys,
I'm working in the LV panel building field , When I select the type of cable from the manufacturer cataloges,
I see many options regarding the types :
- In Conduit or Air
-  Free flat or Free Trefoil
Which are the more reasonable options for panels ?
Husam
  • Products
RHH
Commander | EcoXpert Master RHH Commander | EcoXpert Master
Posted: ‎2022-06-16 12:28 AM . Last Modified: ‎2022-06-16 12:29 AM
Hello @Husam-89 ,
I am not our company's buyer.
However I do know that we use 90 degrees cable and that we defaulted our cable to be Halogen free.
As most of our customers/client demand Halogen free cable's and components nowadays, mostly due fire safety regulation and goals.
Hopefully this is of any help!
Kind regards,
Rick
Lindamartin
Crewman Lindamartin
Crewman
Posted: ‎2022-07-18 10:56 PM . Last Modified: ‎2022-07-19 09:13 PM
@Husam-89 wrote: Rebaid Login
Hello Guys,
- In Conduit or Air
Husam
Cable size selection is based on three main factors: Current carrying capacity. Voltage regulation. Short circuit rating.
sesa378359
Ensign sesa378359 Ensign
Ensign
Posted: ‎2022-08-18 04:36 AM
Hello @Husam-89 ,
These arrangement are to determine the derating of the cable.
For fair estimate, the cables inside the panels are to be considered as in conduit because of closed surroundings. This shall have large deration in ampacity.
Other point such as flat/trefoil does not have huge impact as the length inside the panel is small for the cables. To have accurate estimate this is to be taken based on the routing of cable inside the panel which will mostly be flat spaced.
These are applicable for MV cables and not for LV cables.
Hope this clarifies your point.
Aravind.
RHH
Hello @Husam-89 ,
Kind regards,
Rick
Lindamartin
Crewman Lindamartin
Crewman
Hello Guys,
- In Conduit or Air
Husam
sesa378359
Ensign
Hello @Husam-89 ,
Aravind.
