Asset Advisor Power Monitoring?
  • Power Distribution IEC
  • Asset Advisor Power Monitoring?
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
EcoStruxure™ Asset Advisor for Electrical Distribution
SaulEspinoza
Ensign SaulEspinoza
Ensign
Posted: ‎2023-10-11 03:02 PM
9
3029
Can Asset Advisor monitor Power? Voltage, Amperage, etc.
Can Asset Advisor gather the information from a power monitor?
Being able to gather the temperature as well as the power information would provide more insight into the health of an asset.
I have seen some information that Asset Advisor can monitor a MV VFD. How does it accomplish the power monitoring? What does the architecture look like?
Saul
  • Power Availability
  • Software
Loic_Baque
Ensign Loic_Baque Ensign
Ensign
Posted: ‎2023-10-13 08:46 AM . Last Modified: ‎2023-10-13 08:49 AM
Hi Saul,
  • YES Asset Advisor can monitor many kind of data, the most used power, currents, voltage …
  •  YES, the key point is AA must receive this data coming from a gateway:
Device (modbus most of the time) ==> gateway ==> Asset Advisor
  • The gateway must be able to read the data from the device (power monitor in your example) and forward it to Asset Advisor
    By “read the data”, I mean know the register table of this device, the unit of each datapoint…
  • YES, AA can associate temperature to an monitored asset.
  • I don’t have information to reply here, but I hope someone else can reply soon.
Perhaps, this link can help you:
https://www.se.com/ww/en/download/document/998-20671877_EAA_Drives/?ssr=true
Best regards,
Victor_Marina
Lieutenant JG Victor_Marina Lieutenant JG
Lieutenant JG
Posted: ‎2023-10-16 03:03 AM
In response to SaulEspinoza
2966
Hi Saul,
Connectivity for ATV6000 is made by Com'X, which is installed and configured at factory, not in brownfield once equipment is shipped to customer site. They keep using Com'X by the time all models are created, tested and validated for Panel server. Any ATV6000 ordered with EAA option gets 1 Com'X inside, with all relevant signals. Picture you shared is definition for connectivity with full scope of options.
Regards... Victor Marina
Loic_Baque
Ensign
Posted: ‎2023-10-17 01:14 AM
2916
After a check, I confirm  the ATV6000 is supported by PanelServer  (PAS600 &  PAS800).
There is a  custom model, that allow  PanelServer  to monitor all  useful  data.
The architecture you first asked is possible yet:
ATV6000 Modbus TCP--->Panel Server--->EAA
About the PM8244, yes there is also a custom  model  for  Panel Server allowing :
PM8000 --->Panel Server--->EAA
Important :  the custom models I talk here are designed for EAA use, so not all the modbus map are  monitored, only the data that EAA need.
Victor_Marina
Lieutenant JG
Posted: ‎2023-10-17 01:58 AM
Hi Saul,
In addition to Loic comment, ATV6000 Drive has their own means to measure current, voltage, energy and power. Following table shows measurements ATV6000 Drive can push into gateway (Com'X or PaS), in turn, into Asset Advisor application (label with Capital letter code correspond with ATV internal coding, same available in ATV6000 manual):
Drive rate - NCV
Drive rate voltage- VCAL
Electrical energy Input GWh – IE3
Electrical energy Input kWh – IE1
Electrical energy Input MWh – IE2
Electrical energy Input TWh – IE4
Electrical energy Input Wh – IE0
Electrical energy Output GWh – OE3
Electrical energy Output kWh – OE1
Electrical energy Output MWh – OE2
Electrical energy Output TWh – OE4
Electrical energy Output Wh – OE0
Main estimated current phase 1
Main estimated current phase 2
Main estimated current phase 3
Main frequency - FAC
Main unbalance voltage - UMV
Main voltage - ULN
Main voltage phase 1
Main voltage phase 2
Main voltage phase 3
Mains active power P – IPRW
Mains apparent power S - ISRW
Mains reactive power Q - IQRW
Power factor Cos - PWF
Power input mains current – PIMC
Power input mains voltage – PIMV
Power input transformer power - PITP
Power output Cell Current - PoCC
Power output cell number - PoCN
Power output Cell type - PoCT
Power output cell voltage – PoCV
I hope this clarifies your question about how Power/energy  information
Replies 9
Loic_Baque
Ensign
Hi Saul,
Best regards,
SaulEspinoza
Ensign SaulEspinoza
Ensign
Posted: ‎2023-10-13 12:45 PM
2981
Thank you Loic. Attached you will find the slide of the ATV6000.
It would be interesting to find out what the architecture looks like.
ATV6000 Modbus TCP--->Panel Server--->EAA?
  • EAA
Victor_Marina
Lieutenant JG
2967
Hi Saul,
SaulEspinoza
Ensign SaulEspinoza
Ensign
Posted: ‎2023-10-16 07:40 AM
In response to Victor_Marina
Victor,
Thank you for your reply.
Is it safe to assume that the ATV6000 communicates to Com'X via Modbus to get the input power and output power information?
Saul
SaulEspinoza
Ensign SaulEspinoza
Ensign
Posted: ‎2023-10-16 07:29 PM
Loic,
For clarification purpose.
Power Monitor = Power Meter like the PM8244. Do you know what data points EAA reads from the Power Meter? I have attached the Modbus Map for your reference.
Loic_Baque
Ensign
2917
Victor_Marina
Lieutenant JG
Hi Saul,
Drive rate - NCV
Main voltage - ULN
SaulEspinoza
Ensign SaulEspinoza
Ensign
Posted: ‎2025-08-15 03:51 PM
In response to Loic_Baque
Loic,
Is there a list of compatible 3rd party Power Monitors that are compatible with Asset Advisor?
Example: GE PQM II Power Quality Meter, Eaton IQ DP-4000
Victor_Marina
Lieutenant JG
Posted: ‎2025-08-25 06:24 AM
Hi Saul,
Asset Advisor is not designed to deliver Power Monitoring, but is compatible with Power Monitoring systems and Power meters, as far as they communicate with Modbus protocol, and gather that information.
There is a service named Power Advisor that better address that domain, with a system level approach.
Reason to connect those solutions or devices to Asset Advisor is to gather measurements required for the asset condition and performance analytics delivered (for instance the current per phase in thermal points, or voltage levels for aging computation). Once we gather measurements like voltage, current, load factor or even THD, we can display in our dashboards, and CSH experts would take them into account for the remote monitoring process they are accountable for, while Asset Advisor analysis is still asset centric. CSH can make conclusions system wide to complete their recommendations (like an overvoltage originated at utility level impacting multiple equipment measured across the system...).
In case of ATV6000, I recommend you to contact Offer manager for ESP for Drives (Nabil Hussain Khilji) to get in deeper discussion.
EcoStruxure Power teams are already working on the new solution that will bring together both domains Power and Asset management, shortly. It is the project known as New Advisor and will support EcoCare membership contracts. Stay tunned to EcoCare channels to know more!
