63A 8P Switch Disconnector
  • Power Distribution IEC
  • 63A 8P Switch Disconnector
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Peter_Hall
Lt. Commander | EcoXpert Master Peter_Hall Lt. Commander | EcoXpert Master
Posted: ‎2022-07-14 02:28 AM
9
4030
Can anyone please give me the part number for an 8P 63A disconnector? I'm looking at using one for a bypass on a change over panel.
  • Power Availability
Christian_Bach
Lt. Commander Christian_Bach Lt. Commander
Lt. Commander
Posted: ‎2022-07-18 05:41 AM
In response to RHH
1
3938
Hi @RHH ,
The request seems to be a 8P switch, not a manual transfer switch (I-O-II). I am interested to understand the application need, let's wait for the information.
Christian
Replies 9
RHH
Commander | EcoXpert Master RHH Commander | EcoXpert Master
Posted: ‎2022-07-14 02:45 AM . Last Modified: ‎2022-07-14 02:46 AM
7
4025
Hello @Peter_Hall ,
I attached the Schneider Electric Transferpact catalogue in PDF.
You can use accessoiries like; mechanical interlocking - for devices with extended rotary handle - 40...160 A
All is described in the PDF attached.
Hope this is of any help!
Kind regards,
Rick
Peter_Hall
Posted: ‎2022-07-14 02:59 AM
In response to RHH
4021
Hi @RHH,
Thank you for your reply. That one will do for one switch. however, it was the wrap around switch for the mains supply that i was looking for. This needs to be an 8 pole gang operated switch 2 position.
Christian_Bach
Lt. Commander
Posted: ‎2022-07-18 12:12 AM
In response to Peter_Hall
5
3960
Hi @Peter_Hall ,
Sorry, probably my english but I don't understand your need. Could you please post a schematic ?
Christian
Peter_Hall
Posted: ‎2022-07-18 12:57 AM
In response to Christian_Bach
3956
Hi @Christian_Bach,
No problems. It is though very simple. the unit needs to be as:
8 poles.
2 position (off/on).
Single central operating handle.
Christian_Bach
Lt. Commander
Posted: ‎2022-07-18 05:30 AM
Hi @Peter_Hall ,
Thanks, so basic switch with 8P operated by a single actuator.
I am investigating with my colleagues from final distribution products, would a toggle type actuator fit your need ?
Would it be possible to share your Bypass schematics (even in private message) ?
Christian
RHH
Posted: ‎2022-07-18 05:38 AM . Last Modified: ‎2022-07-18 05:49 AM
3940
I think I know what you mean, the most common (8P) is 1-0-2 though.
Like the jpg files I attached to this post. Coming from our workshop.
Kind regards,
Rick
Christian_Bach
Lt. Commander
In response to RHH
1
3939
Hi @RHH ,
Christian
RHH
Posted: ‎2022-07-18 05:46 AM
@Christian_Bach ,
Yes, indeed.
Curious we are 🙂
Kind regards,
Rick
Berkhof
Lieutenant | EcoXpert Master Berkhof Lieutenant | EcoXpert Master
Posted: ‎2022-07-18 06:25 AM
Hi @Peter_Hall ,
Maybe 2x NSXna with a MN coil will do the trick? ( 2x C114100LS 2x LV426806 )
Connect the Q1 MN coil to Q2 and the Q2 MN coil to Q1.
As soon u switch one of the to breakers open than the other one will disconnect aswell.
Closing the 2 breakers will be a 2 handed operation. or with a bypass on the MN coils.
Kind regards,
John
