Wadah diskusi seputar PLC,HMI, SCADA dan semua hal seputar otomasi pada proses industri, baik mengenai hal teknis, informasi terbaru dan juga seputar bisnis. Forum ini terbuka unutuk semua system integrator industrial di Indonesia
2024-09-25 05:08 AM - diedit 2024-09-26 12:51 AM
I need to connect 7 3-wire PNP sensors to a PLC.
To save on wiring, is it possible to use common supply and ground for them from the PLC and 1 signal per sensor? So this would become 9 cores in total in a single multicore cable?
pada 2024-10-17 05:07 AM
I see no problem on a solution like that if all signals got to the same DI card or on the same oboard DI.
pada 2024-10-17 02:11 PM
Thank you
