modicon M580 card freezing
Modicon PAC Forum
Select a Country
  • Industrial Automation
  • Modicon PAC Forum
  • modicon M580 card freezing
Trinxs1
Trinxs1 Leader
19
YONGHO-KIM
YONGHO-KIM Mentor
10
ciupol
ciupol
9
Back to Modicon PAC Forum
NavinMarsel1
NavinMarsel1 Contributor
Contributor
Posted: ‎2025-07-31 07:14 PM
448
Dear Team,
I’m currently facing an issue with the BME NOP 0300 module. After importing the .cid file, the PLC freshness appears to be good. However, the data points are not updating in real-time—they seem to be frozen.
Please find the attached screenshot for your reference.
Data Point GGIO1.ind1 quality bad in PLC
Data Point GGIO1.ind1 quality good
Kindly advise on the next steps or any checks I should perform.
  • 02. Modicon M580 ePAC
Siddiqui
Siddiqui Contributor
Contributor
Posted: ‎2025-08-07 04:20 AM
Hi @NavinMarsel1,
I hope that you managed to fix the issue as of now, but in case you are still facing it, please verify the following:
  • Make sure that you are using the latest updated CID file from the IED, import it into the BMENOP0300 module using the Modicon IEC 61850 configuration tool, and perform the IEC 61850 client configuration.
  • Also, the data exchange method should be configured correctly inside the Modicon IEC 61850 configuration tool, such as through reporting or polling. If the reporting mechanism is used, make sure that GGIO1.ind1 becomes part of the dataset while configuring the report control block inside the IEDs.
  • After verifying the above points, if you are still facing an error, I suggest you create a case with the support team and share the exact CID file and the application of the Control Expert where you are facing the issue to proceed further with the investigation.
I hope the above comments will provide help.
Best Regards,
MWS.
