Posted: 2025-07-23 10:49 AM
I am trying to use unity loader to load a project file into an M580. I am connected via USB and when pressing connect, I am prompted to enter the firmware password. When I enter "fwdownload" I get an incorrect password notification.
But in control expert, when I set up firmware password protection, I am able to reset the password to the default "fwdownload" using... "fwdownload". I then build the project, load it to the M580.
But unity loader still tells me the password is incorrect when I try to use it to load the project.
Posted: 2025-07-24 09:25 PM
Steps to Resolve the Unity Loader Firmware Password Issue
1) Double-check the password protection settings in Control Expert:
- Go to Project Settings > Protection > Firmware Download Password.
- Ensure the password is explicitly set to "fwdownload" (case-sensitive).
- Rebuild and download the project again to the M580.
2) Use the correct login credentials in Unity Loader:
- When prompted, make sure:
Username: loader
Password: the exact firmware password you set in Control Expert (e.g., fwdownload),
3) Try connecting via Ethernet instead of USB:
- Some users have reported that USB connections can behave inconsistently with password prompts.
- If possible, try using the Ethernet port and see if the password is accepted.
4) Check Unity Loader version compatibility:
- Ensure you're using Unity Loader v10 or higher, as earlier versions may not support the firmware password feature properly.
5) Clear cached credentials:
- Unity Loader may cache incorrect credentials. Try:
Restarting Unity Loader.
Rebooting the PC.
Reconnecting the USB or Ethernet cable.
Username: loader
Rebooting the PC.
Posted: 2025-07-25 12:36 AM
Please check the current firmware of your M580. If the firmware is v4.x, you cannot use Unity Loader.
Posted: 2025-07-28 01:02 PM
Thank you for the reply. Is there an alternative I can use to load and run projects to my M580, without the need of Control Expert when the PLC firmware is v4.x? We would like to find a way for our techs out in the field to load projects to the M580, without the need of a license, in a pinch.
Posted: 2025-07-30 10:04 PM
@Kkalpoe Ecostruxure Automation Device maintenance V3.3.142.0 is the latest version of our firmware management tool. I have not tested this but EADM has the ability to download projects as well, see the attached screenshot. Follow the instructions provided by Yongho-Kim and RoozeeR. That will help to ensure the firmware is downloaded and then you can try the application.
Posted: 2025-07-31 02:39 AM
As mentioned by @Trinxs1 , you should use Ecostruxure Automation Device maintenance V3.3.142.0.
https://www.se.com/uk/en/download/document/EADM/
I have tried this, and currently doesn't function correctly. I have see there is already a case created to resolve the issue. I advice you to contact your local support, and create a case, so you will be informed as soon as a fix is available.
Posted: 2026-09-15 03:20 PM
I have not been able to connect to any of my M580s, with either Unity Loader or the latest EADM. I am using Control Expert 16.2, Unity Loader 14 SP1. I have tried with both usb and ethernet connections. I have not been able to get the password "fwdownload" to work under any condition.
