SE Modbus Tag node - NODE RED Blocks - SE ModbusWrite
Modicon PAC Forum
Select a Country
  • Industrial Automation
  • Modicon PAC Forum
  • SE Modbus Tag node - NODE RED Blocks - SE ModbusWrite
Trinxs1
Trinxs1 Leader
19
YONGHO-KIM
YONGHO-KIM Mentor
10
ciupol
ciupol
9
Modicon M340
Modicon M580
EcoStruxure™ Control Expert
field url
EcoStruxure™ Augmented Operator Advisor - Runtime
field url
EcoStruxure™ Control Expert - Modicon Communications Server
Load more
Back to Modicon PAC Forum
Posted: ‎2021-11-10 01:15 PM
7
6324
Hello Community,
I was hoping that you could help me set up the SE modbus write block for node red. I have not found a way to join all the values and send them as a complete package to the PLC. I used the JOIN function, but the values were moving from registers to registers like a cycle. I had to use a lot of the SEModbus write blocks individually to get it to work in conjunction with delays so the communication doesn't crash.
I'm adding the image, maybe someone can help me make a little bit smaller.
  • AOA
  • Augmented operator
  • AVEVA
  • AVEVA Insight
Replies 7
Bastian_Schmitz
Bastian_Schmitz Champion
Champion
Posted: ‎2021-11-18 10:07 PM . Last Modified: ‎2025-08-12 05:12 AM
6272
Hello Kevin,
You want to write values in continous registers of the PLC via FC16?
In my opinion you need to put them in an array. But I did not try it.
But did you know the manual to the nodes which you could find Link Node Manual
Maybe this could help you.
best regards
Posted: ‎2021-11-19 03:50 AM
6257
I'd love to help out (and at the same time try the SE nodes for modbus communication), however I'm not able to either complete the offline (no access to file on box) or online (can't resolve npm registry hostname) installation procedures.
Posted: ‎2021-11-19 04:37 AM
In response to Bastian_Schmitz
Already try to put them in an array or a join function, but for some reason, the values keep moving from register to register, but If I do it individually, I have no problem at all.
Posted: ‎2021-11-19 04:38 AM
In response to Anonymous user
6253
It seems you need to get it from Schneider, but I can share it with you. Will you give me your email?
Posted: ‎2021-11-19 04:46 AM
I already reached out to my SE contact for the files.
Thanks for the offer!
RoozeeR
RoozeeR Mentor
Mentor
Posted: ‎2021-11-22 05:43 AM
6223
Hello Tom,
Just sent you the install.
At the moment the install as mentioned in the manual is not available. In future the download should be possible from Exchange (as promised by the offer manager).
R.Roozee
Sr Solution Architect (SAE Master)
Posted: ‎2021-11-22 07:13 AM
In response to RoozeeR
Thanks René,
I'll report back when I got it working.
