Posted: 2021-12-03 07:32 AM
Good evening,
I'm tryng to build a list of valves tag using an DFB ST section scanning an array with a FOR loop, the code use the "CONCAT_STR" to append the carraige return char "$N" and the next valve tag,
I declared a String[256] output in the DFB and connected it to a string of the same lenght, but regardless the dimension, the output variable is cutted to contain only the first 16 chars.
What am I doing wrong?
I tried to use an unused string[256] too, if I try to modify it with the Animation Table the content is cutted in the same manner
Posted: 2021-12-03 07:48 AM
ECE shows by default max. 16 characters. When you select the button in the Animation table menu bar "extended strings" (second from right) more characters will appear.
Posted: 2021-12-03 08:22 AM
Perfect! Thank you so much!
It's a very strange option; is it possible to know the reason about this choice?
