Posted: 2024-06-20 05:34 AM
I have a bunch of remote IO communicating over Ethernet/IP thru a BMXNOC401.2 card. Does anyone know if that I/O is scanned such that its synchronous or asynchronous to the PLC logic?
Posted: 2024-06-23 09:19 PM
I would think that almost all comms are asynchronous. I mainly say this because the READ_VAR FB explicitly states that it requires multiple scan cycles for execution. Even the default repetitive rate of the IO scanner is in the hundreds of millisecond range.
Posted: 2024-06-25 07:16 AM
I might be doing something wrong. I did not think its necessary to use a READ_VAR_FB. The I/O is coming into a BMXNOC401.2 card and the devices are Itoh Denki IB-E03 cards. When I added them to the device list for the 401 card it assigned memory addresses and shows a Scan Rate of 30ms.
I have a meeting with Schneider Electric Tech support this coming Thursday. I'll run my configuration by them.
Posted: 2024-06-26 05:06 AM
You're correct that you don't need to use the READ_VAR blcoks, since you are using the IO scanner built into the BMXNOC401.
Pleas share the response for tech supoport when you can, I'd also like a difinitive answer to where or not the IO scanning is synchronous or asynchronous.
