Posted: 2024-10-22 11:00 AM
I am still new to M580 and getting Modbus over TCP/IP working. I got read register (code 03h) to work but cannot get write to coil (code 05h) using function block DATA_EXCH to work. Here are my code samples along with the M580 manual references I am using and the protection relay I am writing to a 1 bit register ("coil"), if someone can pinpoint the error:
Posted: 2024-12-26 12:42 PM
Please check your data types and data packing. I think your issue is that you need to re-pack the data correctly. The Tx_Data array is INT, but the manual shows the structure as BYTE, WORD, BYTE. You might be better off working in a raw data BYTE array to build up the query, and then use BYTE_AS_WORD and WORD_TO_INT to push into the Tx_Data array for EMIS.
PS - do you need to use the DATA_EXCH? I think you would only use this if you expect a response form the device following the command. The standard Modbus WRITE_VAR can also write to coils, and READ_VAR can read all Modbus types.
Posted: 2025-10-22 08:34 AM
WRITE_VAR use always the function code 15 even if the length is = 1
Posted: 2025-10-22 09:03 AM
To SET coil command the operation code HEX FF is on the High byte of the second register of the Emission data.
In your example should be Tx_Data[1] = 16#FF1B (in Dec = 65307)
Tx_Data[2] = 0
