Posted: 2025-06-26 01:00 AM
Hi everyone. We are quite new in M580S and still learning.
We are working on a project using M580S with CRA31210 module configured for a remote drop. Kindly refer attached architecture.
After setting up all equipment, powered up and downloaded the configuration, we noticed that all I/O modules are having: -
Besides that, the CRA module is having LED RUN (green) - off as well.
Kindly clarify, is the error on I/O modules are related to the CRA? Kindly guide us on how to troubleshoot this problem. Thank you very much.
Posted: 2025-06-30 08:05 PM
Hi all. Just to update the status.
We finally confirmed the I/O modules LED ERR (red) - blinking was due to BMECRA31210 firmware ver. 2.40 incompatibility with CPU firmware ver. 3.20.05. It requires a firmware 2.60 or later.
We downloaded SV2.60 and upgraded BMECRA31210 firmware accordingly. After some adjustments, we managed to solve the issue. Thanks again.
Posted: 2025-06-26 10:13 PM
Check and correct CRA drop address switches
> The CRA31210 uses rotary switches to set its drop address.
> If the address is not correctly set or doesn't match the configuration in Control Expert, the I/O Modules will not be recognized.
Posted: 2025-06-27 03:43 AM
Hi @YONGHO-KIM ,
Thank you for your response. We have set CRA drop address switches as below: -
We further checked the CRA firmware ver. is 2.4. Could it be due to incompatibility issue with CPU firmware ver. 3.2? If yes, is there a way to upgrade the CRA firmware? Thank you.
Posted: 2025-07-01 12:32 AM
Hello Eyanto,
You have downloaded a configuration, which include the CRA31210 and the IO modules?
At least the CRA must have a RUN light on. Please check for the CRA module:
1: Is the switch on front of the module set o the configured Drop address?
2: Is the configured module selected correctly: Is it according the module type BMXCRA31210 or BMECRA31210? This is a common mistake, if the type is not set correct as it's only 1 letter difference (X or E).
br
Posted: 2025-07-01 02:08 AM
Hi @RoozeeR ,
Yes, we have downloaded the configuration with BMECRA31210 and X80 I/O modules. The CRA rotary address switches have been set as below: -
Now the CRA indicates LED RUN (green). Thank you.
