M580S BMXSAI0410 Wiring Scheme
Modicon PAC Forum
Select a Country
  • Industrial Automation
  • Modicon PAC Forum
  • M580S BMXSAI0410 Wiring Scheme
Trinxs1
Trinxs1 Leader
19
YONGHO-KIM
YONGHO-KIM Mentor
10
ciupol
ciupol
9
Back to Modicon PAC Forum
Eyanto
Eyanto
Contributor
Posted: ‎2025-07-01 06:27 PM
1157
Hi everyone. This is our first experience using BMXSAI0410.
We need further clarification on the wiring scheme with reference to Modicon M580 Safety Manual QGH46982.11 05/2025, page 55 of 418. As shown by the diagram, we opted the first wiring scheme for all AI signals which is current source.
We are expecting for 2-wire current loop 24VDC powered configuration. However, during internal FAT, we measured zero voltage at the respective Pin no. 1 and 3. Does it indicates that we need to have external 24VDC power distribution for each channel?
Thank you.
  • 03. Modicon PAC Safety
YONGHO-KIM
YONGHO-KIM Mentor
Mentor
Posted: ‎2025-07-02 04:32 PM
3
1128
The module itself does not supply 24VDC power. Therefore, an external 24VDC power source is required for each channel.
This is consistent with Schneider Electric’s typical analog input module design. In particular, for 2-wire sensor configurations, the loop power must be supplied externally. The module only measures the loop current and does not provide the power to drive the loop
YONGHO-KIM
YONGHO-KIM Mentor
Mentor
Posted: ‎2025-07-02 06:19 PM
In response to Eyanto
1
1125
The first wiring is for a 2-wire power configuration, while the second wiring is for a 4-wire power configuration.
Replies 4
YONGHO-KIM
YONGHO-KIM Mentor
Mentor
3
1129
Eyanto
Eyanto
Contributor
Posted: ‎2025-07-02 06:02 PM
In response to YONGHO-KIM
1127
Hi @YONGHO-KIM,
Thank you very much for your response.
Besides that, we would like to understand more about the second wiring scheme as shown by the diagram. There is external 24VDC power supply at the circuit. May we know what is the difference with the first wiring scheme? And at what situation we should use the first and the second wiring schemes. Thank you.
YONGHO-KIM
YONGHO-KIM Mentor
Mentor
1
1126
Eyanto
Eyanto
Contributor
Posted: ‎2025-07-02 07:01 PM
Hi @YONGHO-KIM,
Thank you again for your clarification. Appreciate your help. 👍
