Posted: 2023-06-18 11:00 AM
Hi there,
I am trying to update the firmware in M580 BMEH2040 HSBY system (level 2 for R IO), from 3.20 to 4.1.
I am using usb connection and Automation Device Maintenance.
The update always stops at 100% when I'm going from version 3.20 to 3.99 and gives an error saying something like
"ERROR_INVALID_CREDENTIALS"
I have tried to reset the M580 BMEH2040 units by following these guides:
https://community.se.com/t5/Modicon-PAC-Forum/How-to-Reset-a-M580-CPU/td-p/378726
but still it won't work. I use password fwdownload and nothing changes.
I also tried to deactivate the firewall on the virtual machine I am using, didn't work.
Hope you can help me.
Grétar Már
Posted: 2023-08-23 02:35 AM
Hello Gretarmark_
I hope you already found a solution.
In case you are still facing this issue please use the following instruction provided by Schneider Electric:
Modicon M580 Controller Firmware (schneider-electric.com)
After the installation of FW 3.99 you have to follow the the instructions from Step 2 in the PDF.
The necessary credentials can be found on page 20.
Important is that you need to remove and add the device again as described on Page 19
Posted: 2023-08-28 02:22 AM
Hello Grétar
After the update try to connect using the factory IP. I attached an example video.
How to Upgrade M580 CPU Legacy Firmware to Version 4.xx | Schneider Electric Support
https://www.youtube.com/watch?v=AWipD9PwKWg
On the other hand, you should check that you have the latest firmware and EADM versions. I have attached some additional links.
MODICON M580 BMEx58x0x0 intermediate Firmware OS3.99.07
https://www.se.com/ww/en/download/document/BMEx58x0x0_SV03.99.07/
Modicon M580 BMEx58x0x0 Firmware SV04.10.13
https://www.se.com/ww/en/download/document/BMEx58x0x0_SV04.10/
EcoStruxure Automation Device Maintenance (EN) Version : V3.2.124
https://www.se.com/ww/en/download/document/EADM/
If you still can't update the CPU, contact the Schneider technical support in your country
Good Luck!
Ricard
Posted: 2023-09-19 11:27 PM
Hello Grétar
Good Luck!
Ricard
