Posted: 2024-11-28 10:00 PM
Is there a way to export an existing Device DTM with all its Request Items then re-name it and import back into the project? Aim is to avoid manually configuring all requests for identical devices manually.
Ideally we'd like the process to create all the DDTs for the new device as well.
Posted: 2024-12-01 11:50 PM . Last Modified: 2024-12-01 11:51 PM
If you have an existing NOC module and you wish to duplicate it, you can do this using the M580 Application Update. Export the module configuration into a ".ZHW" file. Import it into the converter and specify a target spare slot in the CPU. The new module will be created with the configuration, and this can be modified.
It is not a solution that can be edited in a spreadsheet however it is a way of transferring DTM configurations.
Posted: 2024-12-02 09:09 PM
Thank you for your reply.
Please note that we are not adding the DTMs under NOC, we are adding them under the M580 controller directly. There is no option to export the controller DTM config, is there?
Posted: 2024-12-03 04:17 PM
Sorry this is limited to the NOC module.
