Control Expert V15.1 and V15.2 close automatically
Modicon PAC Forum
Select a Country
  • Industrial Automation
  • Modicon PAC Forum
  • Control Expert V15.1 and V15.2 close automatically
Trinxs1
Trinxs1 Leader
19
YONGHO-KIM
YONGHO-KIM Mentor
10
ciupol
ciupol
9
Back to Modicon PAC Forum
FransvanDyk
FransvanDyk
Explorer
Posted: ‎2022-09-08 04:55 AM
5980
Control Expert V15.1 and V15.2 close automatically if:
* I create a new project: Loads till security menu, and then closes the whole application ( takes about 5 sec )
* Opening an existing project
Also, I have experienced it whilst working on my other computer. It just crashes and closes completely.
WhatsApp Video 2022-08-10 at 11.02.22 AM.mp4
  • 06. EcoStruxure Control Expert
Replies 9
Robert_Willis
Robert_Willis Troubleshooter
Troubleshooter
Posted: ‎2022-09-09 07:21 PM
5939
I am assuming that you have V15.1 and V15.2 on two separate computers and they are experiencing the same issue. Was the system working correctly before? If yes what software have you installed since eth last time ECE worked correctly?
FransvanDyk
FransvanDyk
Explorer
Posted: ‎2022-09-13 11:17 PM
In response to Robert_Willis
Hi thanks for the reply, unfortunately, I have tried uninstalling any software installed recently, but the problem is still not solved 😞 . I really don't want to re-install windows , but seems like this is the next step.
Robert_Willis
Troubleshooter
Posted: ‎2022-12-09 07:01 AM
What operating system are you running the software on? Please advise the version and build number.
erik.cornelsen
erik.cornelsen
Contributor
Posted: ‎2024-03-02 01:09 PM
I had a similar issue with V16. The only solution I found was to rebuild the whole VM.
bprakash8
bprakash8
Explorer
Posted: ‎2024-07-19 01:57 AM
Is there any solution for this i'm facing the same issues in the 15.3
IsmetCemKaya
IsmetCemKaya Troubleshooter
Troubleshooter
Posted: ‎2025-06-05 11:48 AM
Have you found a solution to this problem ? I have suddenly started experiencing the same issue with my V15.3. I had been using this version for around a year with no issues. However, I can no longer work with it as it closes whenever I try to open backup projects. I have already tried to uninstall and reinstall it, but this hasn't solved the problem.
OS:Windows 11 Pro
OS Build: 22631.5335
Experience: Windows Feature Experience Pack 1000.22700.1081.0
Ismet Cem Kaya
IsmetCemKaya
Troubleshooter
Posted: ‎2025-06-05 12:31 PM
2
2969
I’ve just found a solution. I tested Control Expert with various backups, and everything appears to be working properly again. Also, when I tried removing it, the issue began to reoccur. I hope this helps.
If you followed the standard installation steps, a shortcut should have been created at the path:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\EcoStruxure Control Expert.
Right-click this shortcut, select Properties, go to the Compatibility tab, and check the box for 'Run this program as an administrator.' This solution has worked for me.
Ismet Cem Kaya
iggy684
iggy684 Explorer
Explorer
Posted: ‎2025-06-17 06:28 AM
In response to IsmetCemKaya
1
2802
This worked! Thank you so much!
ControlSoft
ControlSoft
Explorer
Posted: ‎2025-07-22 05:34 PM
In response to iggy684
That worked for me too -- V16 .. Thanks Ismet
