Import a device list to discover devices in IT Expert
Device discovery in IT Expert
  • EcoStruxure IT Help Center
  • IT Expert
  • Configuration
  • Device discovery in IT Expert
  • Import a device list to discover devices in IT Expert
  • Mark as Read
  • Video: Device discovery in IT Expert
  • Import a device list to discover devices in IT Exp...
  • Move devices between locations in IT Expert
  • Discover PDU in DCE or ITE after replacing the dis...
  • Discover cascaded PDUs in EcoStruxure IT
EcoStruxure IT Support
Request Support
Back to Device discovery in IT Expert
  • Mark as Read
Sisko JLehr Sisko
‎2025-02-10 01:08 PM
on ‎2025-02-10 01:08 PM
Administrators and Operator users with permissions for All locations can import a device list from Data Center Expert or another source to easily discover devices in IT Expert on up to three EcoStruxure IT Gateways.
An IT Expert subscription is not required.
Modbus device discovery is not supported in EcoStruxure IT.
See Device discovery in IT Expert
File format
  • IP addresses to discover must be in a single column.
  • The columns do not need to be in any specific order.
  • Any extra columns are ignored.
  • The first row can optionally be a header row describing the contents of each column. A header row is not required.
  • The file extension must be .csv, .tsv, .txt
  • The column delimiter must one of the following: colon, comma, tab, pipe, semi-colon, space.
  • The character encoding on the file must be UTF-8.
Example
IP address
192.168.1.12
192.168.1.25
192.168.1.32
192.168.1.42
