Reading Registers via Bacnet
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Reading Registers via Bacnet
Charles_Murison
Picard Charles_Murison Picard
523
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
138
Ramasamy_N
Captain Ramasamy_N Captain
115
sesa55282
sesa55282 Schneider Alumni (Retired)
Posted: ‎2014-10-08 06:53 AM
1733
Customer is trying to read registers of a CM4 and a Micrologic Trip Breaker by using BacNet at his BMS. He claims that he has connected to the devices but only sees blank registers. Any idea what he is missing?
Tags (4)
  • bacnet
  • reading
  • registers
  • via
dborle
dborle Schneider Alumni (Retired)
Posted: ‎2014-10-23 09:53 PM
I don't know, if it is already available (documentation you can find on Shopping Kiosk). But I would suggest to ask your question in the "Light & Room Control" community, there someone should be able to give you an answer. I have such a device on my desk, but let be told, that you can't use it out of the box (not yet). When you like to use it for Modbus devices you will have to write some scripts to put in (which you also can find in the community mentioned before).
Replies 6
dborle
Posted: ‎2014-10-21 02:35 AM
1646
Hi Harry,
These devices normally only are supporting Modbus RTU / Modbus TCP. How can the customer communicate over BacNet to them without using a gateway? I think, that this will be impossible. There is a new gateway from Schneider called spaceLYnk witch should support this function, but I don't have any experience with it.
BR
Daniel
Bojan
Admiral Bojan Admiral
Admiral
Posted: ‎2014-10-21 07:00 AM
1646
Hi is missing Building and Industrial Automation multi-protocol gateway, something like this:
5011
dborle
Posted: ‎2014-10-21 07:11 AM
1646
Hi Bojan,
This looks good!
Does it also support NSX?
Bojan
Admiral
Posted: ‎2014-10-21 07:38 AM
Hi Daniel,
I checked my ProtoNode FPC-N34-0504, and it supports only the following devices:
5013
Maybe you should contact FieldServer Customer Support ( support@fieldserver.com ) and ask if some other gateway versions support NSX.
Best Regards,
Bojan
matt_azzo_com_a
Lieutenant | EcoXpert Master matt_azzo_com_a Lieutenant | EcoXpert Master
Posted: ‎2014-10-23 09:24 PM
1646
As asked previously, can you provide any further info on spaceLYnk and when/where it might be commercially available?
dborle
