FAQ_ Toroids Compatible with Vigilohm Locators
Metering & Power Quality
  • EcoStruxure Power & Grid
  • FAQ_ Toroids Compatible with Vigilohm Locators
Charles_Murison
Picard Charles_Murison Picard
526
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
138
Ramasamy_N
Captain Ramasamy_N Captain
115
Madleen_Laclef
Lt. Commander Madleen_Laclef Lt. Commander
Lt. Commander
Posted: ‎2015-12-23 06:50 AM . Last Modified: ‎2020-04-20 02:51 AM
Document below lists the toroids compatible with Vigilohm Insulation Fault Locators:
- toroids from current catalogue
- toroids from previous Vigilohm catalogues, now obsolete
- toroids from competition
IN3-Information Note_ Toroids compatible with Vigilohm Fault locators.pdf - Box
In addition, the following excel document can help to define the diameter of toroid requested to monitor a feeder:
IN3- Selection of Toroid depending on cables diameter.xls - Box
>>> The criteria of selection is that Diameter of toroid > 1,4 x Diameter of cables bundle
Criterias such as maximum cross section area of conductors; maximum admissible current... do not apply to Vigilohm, since we measure differential currents (these criterias only apply if the toroids are used with Vigirex devices)
NB: A version in french of this document is available here.
  • Insulation Monitoring
Replies 0
