SR2B121JD Higher resistance on one output
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
Send InviteCancel
Posted: 2025-09-3003:32 AM
I have a SR2 B121JD smart relay that has a resistance of 8.6 ohms on one output and 0.5 ohms on the next output. I believe this is causing problems as the two outputs have slightly different voltages when they need to be the same for controlling certain parts of a hydraulic system.
Can anything be done to fix this inside the unit or would I have to find an external fix to this?
