PacDrive WebVisu error: Your connection isn't private
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • PacDrive WebVisu error: Your connection isn't private
Bastian_Schmitz
9
FernandoRodrigues
FernandoRodrigues Support
7
LeTomas
5
Back to Machine and Motion Control Forum
Francesco_Begnoni
Francesco_Begnoni Support
Support
Posted: ‎2025-09-29 08:49 AM
Sometimes you might encounter the following error message when connecting to a Webvisu of a PacDrive controller programmed with Machine Expert 2.2.2.
The message is: "Your connection isn't private."
To connect, you need to type "thisisunsafe" directly on the error page displayed by the browser.
Below is a summary table of the URLs users attempt to use to access the PacDrive Webvisu, along with the resulting effects.
The tests were carried out using the option CommunicationMode = REDIRECT_HTTP_TO_HTTPS.
URL
Effect
1
http://192.168.178.202/webvisu.htm
No response, because the standard port 443 for https does not allow unencrypted connections.
2
https://192.168.178.202/webvisu.htm
Browser reports a security issue with the certificate
net::ERR_CERT_INVALID
It is possible to continue only accepting the risk or typing "thisisunsafe" directly on the browser page
3
http://192.168.178.202:8080/webvisu.htm
This URL will be redirected automatically to the URL of case 2.
4
https://192.168.178.202:8080/webvisu.htm
No response, because port 8080 is not designated for encrypted communication.
5
http://192.168.178.202:8089/webvisu.htm
https://192.168.178.202:8089/webvisu.htm
The port 8089 is not valid. It is valid only for the M262 controller, because the standard port 80 and 443 are dedicated to the Webserver
  • Technical Support and Troubleshooting
Replies 0
