Lxm52 error 8105
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • Lxm52 error 8105
Bastian_Schmitz
9
FernandoRodrigues
FernandoRodrigues Support
7
LeTomas
5
Back to Machine and Motion Control Forum
ciwa
ciwa
Cadet
Posted: ‎2025-06-25 09:19 PM
631
Lxm52 error 8105
I have problem with LXM52 with error code 8105.
I already replace the encoder cable with new one the problem still exist, then replace the servo motor but with same result until replace the servo drive but the problem still exist.
Try to re-route the encoder cable but error still exist.
please advise.
best regards
ciwa
  • Technical Support and Troubleshooting
ravi_kaneria
Lieutenant JG ravi_kaneria
Lieutenant JG
Posted: ‎2025-07-18 10:49 AM
Please connect the Big wire from motor earthing terminal to earthing plate or earthing bar
it is due to potential difference between machine body and earth.
big wire means above 4 sq mm
talha22
talha22
Cadet
Posted: ‎2025-09-18 05:36 AM
@ciwa was this issue solved?
ravi_kaneria
Lieutenant JG
Posted: ‎2025-10-02 10:26 AM
Whenaninvalidencoderpositionisdetected,thediagnosticmessage8105:Encoderpositioninvalidor8195: MachineEncoderpositioninvalidistriggeredandthepositionisadjustedagain. If,however,aninvalidpositionisagaindetectedwhileoneofthesediagnosticmessagesisstillpending,thisdid not leadtoanewpositionadjustment.Duetothiseffecttheencoderpositioncoulddifferfromthephysical position with standard Hiperface encoders. Apendingdiagnosticmessage8105:Encoderpositioninvalidcouldleadtoanundetecteddeviationinthe positionfromthemotorencoderandalostcommutationofthemotor.Thediagnosticmessage8908:Unintended motoroperationdetectedcouldbetriggeredassoonasControllerEnablehasbeenset.
link : https://media.distributordatasolutions.com/schneider_synd_rework/2024q1/documents/ec7749baef19055e30...
please update the software version may be it is solve after that V2.2.2 machine expert
