EcoStructure Machine Expert V2.2
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • EcoStructure Machine Expert V2.2
Bastian_Schmitz
9
FernandoRodrigues
FernandoRodrigues Support
7
LeTomas
5
EcoStruxure™ Machine Expert
Back to Machine and Motion Control Forum
SDemmer
Crewman SDemmer
Crewman
Posted: ‎2025-07-06 06:14 AM . Last Modified: ‎2025-07-06 08:38 AM
802
Good Day,
After installing a device via DTM when saving the project an error message is displayed
"Object reference not set to an instance of an object".
After the above error message is received then the project is unable to be save. "Cannot save project data in Read Only mode"
Controller TM251MESE
Error occurs after adding an ATS480 starter into the project.
What is the cause of this error and how to resolve.
Thank you.
  • Technical Support and Troubleshooting
Replies 7
dnordenberg1
Lt. Commander dnordenberg1
Lt. Commander
Posted: ‎2025-07-06 10:24 PM
776
Does it work if you can remove the device again?
I guess you never saved the project then so does the project work fine every time you open it until you add this DTM?
Checked if the ATS480 DTM you have is the latest?
SDemmer
Crewman SDemmer
Crewman
Posted: ‎2025-07-08 09:35 PM
In response to dnordenberg1
Good Day,
The project works fine until the DTM is added. Then the error is displayed, following that, save does not function as the file is then in "read only" mode.
Project must be closed, unsaved data lost then reopened.
I will check the on the DTM version.
ravi_kaneria
Lieutenant JG ravi_kaneria
Lieutenant JG
Posted: ‎2025-07-18 10:39 AM
733
yes we have similar type of issue we will connect and discuss please contact me on ravi.kaneria@hpautomation.in
also cc mark dhaval.dobariya@hpautomation.in
dnordenberg1
Lt. Commander
Posted: ‎2025-07-19 07:35 AM
1
730
Btw, with 2.2 I hope you mean 2.2.2? 2.2 had lots of changes and it took a while to be stable. I skipped this version entirely because of it and went for 2.3.
I'm also a bit curious, what happens if you start a fresh project and add a ATS480?
Have you tried refreshing the DTM database (even when it thinks there is no need for it)
And as I wrote earlier, make sure the DTM is of latest version.
SDemmer
Crewman SDemmer
Crewman
Posted: ‎2025-07-21 12:00 AM
Below is step by step using V2.3
Create project in V2.3
ATS 480 DTM - V1.2.1.0
Add Device - Ethernet/IP ATS 480
Project Saves Ok
Project closes & Opens OK
Open ATS 480 Device
Edit Configuration - Offline Mode, Device is open with Data Set
Project Saves
Project Close - Error message appears Object reference not set to an instance of an object"
Project can't be closed. Has to be closed from Task Manager
When project is re-opened then last saved changes are there.
When adding another device, Tesys-T, the same error is manifest again.
If the ATS 480 is deleted then project saves and closes OK.
SDemmer
Crewman SDemmer
Crewman
Posted: ‎2025-07-21 09:32 PM
In response to ravi_kaneria
thank you for the suggestion.
It would be better to post solutions/comments on this thread then others can also view the solutions.
Lino_Castanheira
Lino_Castanheira
Cadet
Posted: ‎2025-11-13 01:56 AM
Good morning, I have the same problem, and I’m new here. Has anyone already managed to solve it?
