CFW300 VFD & HMIST6200
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • CFW300 VFD & HMIST6200
Bastian_Schmitz
9
FernandoRodrigues
FernandoRodrigues Support
7
LeTomas
5
Schneider
HMI Screen Templates for EcoStruxure™ Operator Terminal Expert
Back to Machine and Motion Control Forum
marija2001
marija2001
Cadet
Posted: ‎2025-09-25 04:00 AM
209
Hi everyone,
I'm currently working on a simple application involving a CFW300 frequency drive and a Schneider Electric HMI (HMIST6200). I've successfully established Modbus RTU communication between the two devices, and most things are working as expected, I'm able to read parameters from the drive, including an analog input value and any other values without problem. The digital inputs (e.g., Start/Stop switches) are also being monitored correctly – their status shows up properly on the HMI and the communication is established.
However, the issue I'm facing is with writing the Start command to the drive from the HMI. When I press the Start button on the HMI, the motor does not start. The signal appears to be sent (no communication error), but the drive does not respond by starting the motor.
Has anyone encountered a similar issue? Any tips or suggestions would be greatly appreciated!
Thanks in advance!
  • Technical Support and Troubleshooting
ravi_kaneria
Lieutenant JG ravi_kaneria
Lieutenant JG
Posted: ‎2025-10-02 10:13 AM
can you please share application?
also share the manual of the drive and see access level of the drive.
