PACDRIVE - LMC : Master - Slave CAM
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • PACDRIVE - LMC : Master - Slave CAM
Bastian_Schmitz
9
FernandoRodrigues
FernandoRodrigues Support
7
LeTomas
5
EcoStruxure™ Machine Expert - HVAC
Back to Machine and Motion Control Forum
AndreaArduini
Ensign AndreaArduini
Ensign
Posted: ‎2023-04-22 12:04 AM
1221
Goodmorning,
My machine has a CAM Master - Slave managed by PD_AxisModule library in LMC402
I noticed my slave follows the position of the master, visualized  in AXM.ST_ModuleInterface.st_Main.q_lrPositionX, but this value slowly gets different from the real position of master encoder (both real and virtual).
Then, the difference between q_lrPositionX and MasterEncoder.Position increases slowly, so the cam doesn't work.
Anyone has and idea why that happend ? ... and q_lrPositionX which encoder is linked ?
Thanks a lot for your help..
Andrea Arduini
  • Packaging
  • LMC
AndreaArduini
Ensign
Posted: ‎2023-04-27 11:27 PM
Hi everyone,
I solved the problem.
The points of the CAM weren't correct. That introduced a displacement between q_lrPositionX  and the MasterEncoder.position.
Greetings...
AndreaArduini
Ensign
Hi everyone,
Greetings...
