We Value Your Feedback!
Could you please spare a few minutes to share your thoughts on Cloud Connected vs On-Premise Services. Your feedback can help us shape the future of services.
Learn more about the survey or Click here to Launch the survey
Schneider Electric Services Innovation Team!
M172P* JMP instruction
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • M172P* JMP instruction
Bastian_Schmitz
8
FernandoRodrigues
FernandoRodrigues Support
6
Francesco_Begnoni
Francesco_Begnoni Support
5
LeTomas
5
EcoStruxure™ Machine Expert - HVAC
Back to Machine and Motion Control Forum
obscuresc
Lieutenant JG obscuresc
Lieutenant JG
Posted: ‎2024-07-15 10:29 PM
523
I am looking at using a JMP instruction in Structured Text for handling fatal errors in my application; I would like to be able to jump forward between programs to avoid standard routines.
Below I am testing the syntax with respect to the path in the ESME HVAC Help documentation
EcoStruxure Machine Expert HVAC > Software > Ecostruxure Machine Expert - HVAC - Operating Guide > Programming > Language Reference > Common Elements > Operator and Standard Blocks
Spoiler
JMP label;
label : cnt := cnt + 1;
All I receive is
MAIN(1) - error S1312: label => Syntax error
This appears to be the same as syntax of other platforms (i.e. CodeSYS, Beckhoff).
I am using EcoStruxure Machine Expert HVAC v1.6.0.
What am I doing wrong?
Cheers.
  • HVAC
FedericoM
Commander FedericoM Commander
Commander
Posted: ‎2024-07-17 01:21 AM
JMP is not supported on ST language (I will ask to improve documentation).
Sometimes I use RETURN to exit from a program and do more or less what you're trying to do.
FedericoM
Commander
This is a heading
