Help Needed: Schneider M241 PLC Error - Red ERR LED Flashing Fast
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • Help Needed: Schneider M241 PLC Error - Red ERR LED Flashing Fast
Bastian_Schmitz
9
FernandoRodrigues
FernandoRodrigues Support
7
LeTomas
5
Logic Controller - Modicon M241
Back to Machine and Motion Control Forum
Advance_Serhat
Advance_Serhat
Cadet
Posted: ‎2025-01-07 10:08 AM
1609
Hello everyone,
I’m currently facing an issue with my Schneider M241 PLC, and I’m hoping someone here might be able to help. The problem is as follows:
The ERR LED on the PLC is red and flashing rapidly.
According to the manual, this indicates an internal error.
Steps I’ve Taken So Far:
When I power cycle the PLC (turn it off and back on), the error disappears, and the PLC works normally for a while.
Checked the wiring and connections to ensure everything is properly connected.
Tried reloading the application program via EcoStruxure Machine Expert, but the error remains.
Verified that the firmware version is up to date.
Despite these attempts, the error is still present. I suspect it could be related to the system configuration or possibly a hardware issue, but I’m not sure how to proceed.
Additional Information:
There is no visible fault or damage on the hardware.
The system was working fine until this issue occurred unexpectedly.
I’d appreciate any insights or suggestions on how to diagnose or resolve this error. If anyone has encountered a similar issue, your advice would be invaluable!
Thank you in advance for your support!
Best regards,
  • Modicon M2xx
FernandoRodrigues
Support
Posted: ‎2025-01-09 12:26 AM
You can access the M241 webpage via browser (e.g. Chrome) and there will many further diagnostics and logs available that can give more details of what could be wrong.
FernandoRodrigues
Support
