EcoStruxure Machine Expert, PacDrive3 Full Template Simulation
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • EcoStruxure Machine Expert, PacDrive3 Full Template Simulation
Bastian_Schmitz
9
FernandoRodrigues
FernandoRodrigues Support
7
Francesco_Begnoni
Francesco_Begnoni Support
5
LeTomas
5
Back to Machine and Motion Control Forum
s19n
s19n
Cadet
Posted: ‎2021-07-17 04:12 AM . Last Modified: ‎2021-07-17 04:15 AM
2169
Good morning.
It is possible to run a simulation in Machine Expert EcoStruxure using PacDrive 3 Full Template without LMC?
I tried do it but it doesn't work. I mark "Simulation" option and next login, download application and after that I can't leave "Start" step into SR_MainMachine.
I'm hoping you can help me with it.
  • PacDrive
  • PacDrive
  • simulation
  • template
Ralf
Lieutenant JG Ralf Lieutenant JG
Lieutenant JG
Posted: ‎2021-07-18 11:45 PM
Hello s19n,
the "simulation" option can be used to test pure logic in EcoStruxure Machine Expert without using hardware (LMC, M262, etc.). If you want to test a PacDrive application project we recommend to use LMC controller. You can set all drives to virtual mode and test your application.
Without LMC you cannot run PacDrive Applications or the Full Template as the "simulation" does not provide the any PacDrive firmware functions. In your case the START action is checking if the PacDrive Controller has booted up properly and will not receive any feedback as there is no response for a firmware function call.
Hope that helps.
Best regards
Ralf
