Cannot connect to M241 over ethernet
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • Cannot connect to M241 over ethernet
Bastian_Schmitz
9
FernandoRodrigues
FernandoRodrigues Support
7
Francesco_Begnoni
Francesco_Begnoni Support
5
LeTomas
5
EcoStruxure™ Machine Expert
Back to Machine and Motion Control Forum
MedSelmi
Ensign MedSelmi
Ensign
Posted: ‎2022-05-15 04:52 PM
4
6710
Hello!
I unboxed new TM241CE24T/U and I upgraded Firmware to v5.1.9.21 for using with machine expert v2.0.
My problem is that I can connect to PLC over USB but not over Ethernet, even I can ping to its IP Address and I can access to Plc over web page.
Can You help me please ?
  • Modicon M2xx
LeTomas
Lt. Commander
Posted: ‎2022-05-16 12:00 AM
2
6684
Hi @MedSelmi ,
If you are trying to connect to the M241 via ethernet or USB it is important that the gateway is activated.
In the case of the Ethernet connection I always add the device ip address in the "Statis Remote Connections" like this:
The device it is shown as "Connected as client".
Verify also that your laptop/pc is in the same network as the controller.
Best regards,
Letomas
Replies 4
KJBER
Ensign KJBER
Ensign
Posted: ‎2022-05-15 10:37 PM
Try IP Adress via NAT (Remote TCP) with port 1105.
LeTomas
Lt. Commander
2
6685
Hi @MedSelmi ,
Best regards,
Letomas
MedSelmi
Ensign MedSelmi
Ensign
Posted: ‎2022-05-16 09:49 AM
In response to LeTomas
Thank you for your support! it's working.
nauvalaprillian
Crewman nauvalaprillian
Crewman
Posted: ‎2024-12-18 09:14 PM
why is mine always like this, i have been waiting for it for quite a long time but still can't connect
