Posted: 2024-12-23 01:14 AM
Good morning Experts,
We have started a new installation integrating 18 ATV930 drives. The drives all drive tyres, sometimes with 2 motors in parallel behind 1 drive. These are solutions we apply very often with positive results.
However, in this installation, the motors start vibrating and make a strange noise from +/- 40Hz. This for both dual and single motors. Tried everything as factory setting, tuning again.... Only adjusting the SLP (0%) and UFR (0%) seems to do the trick. Also the current then goes down.
What could be at the root of this phenomenon?
Posted: 2025-01-02 01:28 AM
Did you have the nameplate of the motor? Which motor control did you choose?
