ATV930 Speed Loop Optimization
  • Industrial Automation
  • Solutions for Motor Management
  • ATV930 Speed Loop Optimization
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Boris11
Boris11
Cadet
Posted: ‎2024-01-25 04:16 PM
2378
Hello everyone!
I kindly ask you to help me with Speed Loop Optimization for ATV930:
The PFC is working correctly, but I have a problem with motor speed fluctuation
around reference speed in FVC control mode (closed loop).
It is about 3-4 rpm @ 1500 rpm, but it leads to mechanical stress for gearbox
in my case. How to remove or decrease the motor speed fluctuation?
Best regards,
Boris Churkin
  • Drives & Motor Control
BJacqz
Commander
Posted: ‎2024-08-22 02:46 AM
Speed loop gain settings are available in your product. I advise you to use SoMove software, you will then easily be able to see all the speed loop optimization settings.
SSL, SPG & SIT are the first settings I would propose to set, and you have much more, a test of moving one setting at a time will help you to find the good compromise...
Hope it helps
Bruno Jacqz, Drives training leader
Replies 8
BJacqz
Commander
Hope it helps
Denys
Crewman Denys
Crewman
Posted: ‎2025-01-27 02:08 AM
1956
I have same issue with ALT930 for hoist application in a close loop operation. With 50Hz speed setpoint, the RPM is fluctuate around 5 RPM. When I reduce speed to 45Hz, it became stable.
I'll try with the proposed solution by BJacqz
Denys
Crewman Denys
Crewman
Posted: ‎2025-01-27 04:52 AM
In response to Denys
And it's working. I solve the problem with fluctuation.
It didn't appear on the smaller size motor like 160kW, also hoist. So default settings were enough. But for 250kW motor hoist, it was a problem with fluctuation.
Now after reducing proportional SPG (from 40 to 10%) and increasing SIT (from 150ms to 2000ms) it working well. During the load test will check again.
Slayer90
Slayer90
Cadet
Posted: ‎2025-02-13 04:50 AM
1856
Hy guys, I have same problem with hoist application, motor power 132kw. With fix speed after ramp up the current star abnormaly fluctuation like a sine signal. If i set a mode svc V Instead Fvc all works fine. I checked all for motor encoder and switch to another drive but still works bad.. Any idea for the problem? I tried to change values for speed loop but Nothing change.
Thanks for help
Denys
Crewman Denys
Crewman
Posted: ‎2025-02-14 11:55 PM
In response to Slayer90
1804
Hello @Slayer90 ,
I am not professional drive commissioning engineer and also require a lot of support, but I had similar problem before, when in FVC (with encoder) there was a speed fluctuation and in SVC mode (without encoder) wasn't.
We also replace the inverter and the encoder and even put a temporary encoder cable (which by the way improve, but not solve the issue).
Solution in my case, was the encoder cable proper earthing, to prevent the cable magnetization. The trick was in earthing the encoder cable shield to the inverter body (Encoder cable shielding, ATV930 Installation manual) and to connect this shield to the encoder's earth terminal. Encoder (we use AB type) has 7 terminals, as power, neutral, A+/B+, A-/B- and one more for the earthing connection, where we connect the cable shield, which was earthed on the drive side only.
After the proper connections the fluctuations helps.
And right now it come back after mechanical disassemble and assemble the hoist  gearbox. And in any mode FVC or SVC I have fluctuations in speed. This one is really strange and I'm looking for solution. Sure will ask mechanical to disassemble it again.
Slayer90
Slayer90
Cadet
Posted: ‎2025-02-17 12:46 AM
ok thanks for the information. However, I have current fluctuations, not speed. in my case I solved the problem by inserting a value increased by approximately 10% of the rated motor current instead of the motor current write on motor nameplate. Most likely the engine has some problem or the nameplate on it has some incorrect value. I had also tried with a temporary cable for the encoder but nothing had changed.
Ramazan_Tuncer
Ramazan_Tuncer
Cadet
Posted: ‎2025-04-04 05:02 AM
Dear all,
I have the same problem with closed loop control in an extruder application with no load. Only the gearbox connected to the motor at the moment. 75 Hz is the nominal speed of the motor and these fluctuations starts at 60 Hz. I tried to optimize the speed performance with gain parameters SPG, SIT and even tried with high performance speed loop control.
My observation is that these fluctuations start when the actual torque comes around 0%.
We will couple the load soon and I don't know if we will have the same problem at load.
Any suggestion is welcome.
Thanks in advance.
SESA153041
Crewman SESA153041 Crewman
Crewman
Posted: ‎2025-04-07 12:29 AM
We have a similar experience on a 800kW Archimedes screw application driven by an ATV9B0C80Q6X1 + asynchronous WEG motor in closed loop.
If we monitor SRFR (blue curve) we notice speed oscilations of about 0,3Hz around 50Hz.
We tried to solve this issue by changing SPG, SIT, SFC, CRB, CRTF, FFH,... but none of these parameters seem to have an influence.
Feel free to share your comments.
Kind regards.
