"Access Denied" messages during a CyberStation 1.9x installation
  • "Access Denied" messages during a CyberStation 1.9x installation
  • ScottLeedberg
    ScottLeedberg
  • RogerHa
    RogerHa
‎2018-09-07 06:09 AM
Trying to install CyberStation 1.9x.  It completes but then pops up 6 errors saying "Access denied"
CyberStation 1.9x
Microsoft hotfix KB942288-V3 is installed or files are not getting registered
Verify that you are installing Cyberstation with Admin rights
Uninstall MS hotfix KB942288-V3 .  To do this see below.
  1. Click on Start then settings then select Control Panel from the Windows menu.
  2. Double click Add/Remove programs.
  3. In Add/Remove programs make sure the "Show Updates" checkbox on the top of the window is selected.
  4. Scroll through the list of installed item and find the Microsoft update named "KB942288-V3"
  5. Select the update and then click the "Remove" button.
  6. Once complete shut down and restart the PC and reinstall CyberStation.
Note: If KB942288-V3 was slipstreamed into the image that was used to install XP SP3 then you will not see this in Add/Remove programs
Please use the link below to download a batch file to register some of the files that aren't getting registered.
Copy it into c:\Program Files\Continuum, unzip the text file. Open the file and "Save As" a batch file and then run it.
AccessDeniedRegisterFiles191.zip
  • 4471
