Windows Remote Desktop (RDP) is not supported by the TAC Vista Licensing system
  • Windows Remote Desktop (RDP) is not supported by the TAC Vista Licensing system
  • MathiasBj
    MathiasBj
‎2018-09-06 02:47 PM
Windows Remote Desktop (RDP) is not supported by the TAC Vista Licensing system.
TAC Vista
  • Windows 2000, Windows XP, Windows Server 2003
  • Remote Desktop Connection
This feature is often seen as remote control feature but is actually a terminal server feature.
The TAC Vista Licensing system does not support this feature.
Using this feature as a remote control application causes every connection to spawn a new instance of the terminal server. When disconnecting, this instance will remain loaded and all applications started will continue to run.
This can, of course, generate some problems like opened graphics generating a lot of unnecessary traffic on the field buses.
  • 3077
