Will Continuum communicate with a third party system?
  • Will Continuum communicate with a third party system?
‎2018-09-10 06:23 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:29 AM
What X Drivers are available?
All Continuum controllers that support X Drivers (XDrivers)
3rd Party interfaces
How to find out what standard X Drivers are available to integrate with Continuum controllers.
  • The Third Party Communicates Interface and Protocol Brochure can be found on The Exchange Download Center that lists all available X Drivers and product compatibility.
  • Also all of these listed drivers are available for download from The Exchange Download Center here for use on X Driver enabled controllers.
  • Should a new driver development be required, or other special interface; then you can contact the team that develop X Drivers: Adam.Summers@Schneider-Electric.com You will need to provide protocol details if you require a quotation.
Tags (6)
  • 5376
  • customer
  • developments
  • services
  • technical
  • upgrades
