Where can I obtain standard Plain English example functions?
  • Where can I obtain standard Plain English example functions?
‎2018-09-10 11:48 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:27 AM
Where are example Plain English programs and functions stored for typical BMS applications?
Andover Continuum
Plain English (PE) Functions and programs.
ACSM, PID, Optimiser, ISM, First Aid.
Standards
Bacnet Optimiser
It is always easier to write your Plain English programs starting from documented examples rather than a blank page. What is available?
The following link is to a .zip file containing various BMS standard modules originally developed by the UK Application engineers for Infinity SX8000 and were known as the Infinity Standard Modules (ISM's), they were then updated to Andover Controls Standard Modules (ACSM's) for Continuum.
These modules are example functions or building blocks that can by used globally by application engineers to provide the control and monitoring appropriate for your own buildings.
Link: Click here.
In addition to these functions other examples are in the online help for the corresponding Plain English keywords, and other applications can be found on the Forums; see Sample PE functions and programs for further details.
For Smart Sensor examples see Example programs for Smart Sensors TTS-SD-LCD-1 and TTS-SD-LED-1 for details.
For example Security programs see the Download Center link, Click Here.
ACSMs.zip
  • 5327
0% helpful (0/1)
