What sensors does the DC1400 optimiser/compensator require?
  • What sensors does the DC1400 optimiser/compensator require?
  • sesa139513
    sesa139513
  • Gary
    Gary
‎2018-09-06 10:37 AM
Sensors required
DC1400 sensors
Old        Description        New Part Number
Spec
DRT3454    ROOM SENSOR                                                      STR600/004604100
DOT0002   OUTDOOR SENSOR                                               STO600/5126060000
DWT0001  IMMERSION SENSOR                                              STP660/5126080000 (NO POCKET SUPPLIED)
DST0001   STRAP ON SENSOR                                                STC600/5126070000
Pockets available:
DWA0001    BRASS POCKET ADAPTOR                                 9121058000
DWA0002    IMMERSION STAINLESS POCKET 120MM           9121060000
DWA0003    IMMERSION BRASS POCKET 200MM                  9121062000
DWA0004    IMMERSION STAINLESS POCKET 200MM           9121064000
DWA0005    IMMERSION BRASS POCKET 120MM                  9121066000
  • Field Devices
Tags (2)
  • 12616
  • replacement
