Visio will open but LonMaker menu is missing from the toolbar, the features are unavailable, or Error: "unable to launch visio with file lonworks.vst"
  • Visio will open but LonMaker menu is missing from the toolbar, the features are unavailable, or Error: "unable to launch visi...
  • SESA116857
    SESA116857
‎2018-09-07 02:19 AM
Visio will open but LonMaker menu is missing from the toolbar, the features are unavailable.
Error: "unable to launch visio with file lonworks.vst".
TAC Vista
  • Echelon LonMaker 3.0
  • Echelon LonMaker 3.1
  • Echelon LonMaker Turbo (Ver 3.2)
Configurations must be set to link LonMaker and Visio so they run together.
Please consult Echelon's bulletin on this matter at Echelon's website.
The bulletin states that only the following should be in the Add-ons field:
C:\LonWorks\LonMaker;1033\Solutions;
To fix the problem, you also need to add:
C:\LonWorks\LonMaker\Visio
It is also necessary for the following to be enabled (Macro Security).
In the Tools > Options > Security menu, verify that all options below are selected:
  • Enable Microsoft Visual Basic for Applications
  • Enable Microsoft Visual Basic for Applications project creation
  • Load Microsoft Visual Basic for Applications projects from text
  • Enable COM add-ins
  • Enable Automation events
  • 2811
