Valve, Actuator, Sensor, Field Device, Peripheral, HVAC Control Devices Datasheets and Catalogues, Selection Tool.
  • Valve, Actuator, Sensor, Field Device, Peripheral, HVAC Control Devices Datasheets and Catalogues, Selection Tool.
‎2018-09-10 07:32 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:23 AM
Valve Datasheet & Catalogue
Actuator Datasheet & Catalogue
Sensor Datasheet & Catalogue
Field Device Datasheet & Catalogue
Peripheral Datasheet & Catalogue
Selection Tool
Actuator
Valve
Sensor
Field Device
Peripheral
HVAC Control Device
Selection Tool
Need for valve and actuator information.
Need for sensor information.
For European and American Field Device and Valve datasheets/technical publications and catalogues click here to go to the website and select which range that is required.
Or the EMEA  sensor catalogue  or the valve and actuator catalogues can be download from the Download Center
For the Sensor selection tool click here.
For the Heat Meter selection tool click here.
For the Cross Reference selection tool click here.
  • Field Devices
  • 6613
