Using Lmtools in Windows Vista/7/Server 2008
  • Using Lmtools in Windows Vista/7/Server 2008
  • SESA116857
    SESA116857
‎2018-09-06 02:28 PM
Lmtools cannot start/stop service or make changes to license method
  • Vista 5.1.0 or higher
  • Windows Vista, Windows 7, Windows Server 2008
Due to the security rules in Windows Vista or Windows 7 when UAC is enabled Lmtools does not have access change the properties of the license tools and start or stop the service.
Configure Lmtools to Run as Administrator
  1. In the start menu browse to "All Programs\TAC\TAC Tools 5.1.x\Lmtools" or "All Programs\Schneider Electric\TAC Tools 5.x.x\Lmtools" and right click on the shortcut and select Properties.
  2. In the compatibility tab click the "Run this program as an administrator" and click OK.
  3. When you run the Lmtools program it will prompt you to allow access to the computer. Select Allow.
    Note: These steps will have to be done each time you install Vista on the computer.
  • 3910
