Synchronize Continuum system to external time clock
  • Synchronize Continuum system to external time clock
  • sesa116871
    sesa116871
‎2018-09-06 01:30 PM
Is it possible to synchronize the time in a Continuum system to an external Time Server?
Continuum Cyberstation and webClient
No known cause
The only way to synchronize a Continuum system time to an external time source is to synchronize the Primary Access Server (or desired Cyberstation)  with an external time server or time source using Windows or some other time synchronization program, then using the Cyberstation to sync its time with the controllers on the network.
  • 5778
