Setting the firewall port 135 for a Vista Server running on Windows 7
  • Setting the firewall port 135 for a Vista Server running on Windows 7
‎2018-09-07 02:36 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:59 AM
The process for opening up port 135 in Windows 7 is not documented in the installation manual.
Vista Workstation connections to remote Vista Server will not work.
Windows 7
Vista 5.1.X
With DCOM port 135 blocked by the windows firewall Vista Server communications will not work between Vista Servers and Workstations over a network.
Set the DCOM setting as needed using the Vista installation Manual.
Note - You will need to be logged on to Extranet for this document to be accessed.
Then create a new Inbound Rule for port 135 as described on the Microsoft Website with the following settings:
  • Rule Type: Port
  • Protocol and Port: TCP and type specific port 135
  • Action: Allow the connection
  • Profile: Domain; Private and Public
  • Name: DCOM
  • Finish
Link to Microsoft website.
  • 4861
