Script Programs in Continuum compared to StruxureWare Building Operation and using floats (32 bits) and 64 bit numbers.
  • Script Programs in Continuum compared to StruxureWare Building Operation and using floats (32 bits) and 64 bit numbers.
  • Dave_Shore
    Dave_Shore
  • sesa139513
    sesa139513
‎2018-09-06 01:43 PM
Last Updated: Dave_Shore Schneider Alumni (Retired) ‎2023-10-17 07:13 AM
With Script Programs in Continuum we were able to check the variable time against an integer value. Like "if time>500 then...".
In StruxureWare Building Operation time is of the type datetime, no longer an integer.
  • Script Program
In StruxureWare Building Operation a datetime internally is now a 64 bit number, so dates can go beyond the year 2038 which was the top limit for Continuum.  Numbers in script for StruxureWare, like in Continuum are just floats ( 32 bits ) so when trying to map a 64 bit number ( the date ) into a float it is not going to work.  You will get very erroneous readings, therefore the ban.
Here are some examples of the correct StruxureWare program:
Remember that for the dates, you can only compare dates to dates, not dates to numbers…
In general,
you CAN do the following:
    compare dates to dates                ==>   if Date1 > Date2  then
    add numbers to dates                   ==>    LaterDate = LastDate + 24*3600
    subtract numbers from dates         ==>    EarlierDate = LastDate - 24*3600
you CANNOT do the following
compare dates to numbers                ==>   if Date1 > 500  then
Labels (2)
Tags (2)
  • 5373
  • DavidShore23
