Running Sigma Server as an Application
  • Running Sigma Server as an Application
  • CraigEl
    CraigEl
  • Gary
    Gary
‎2018-09-06 02:08 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-08 06:22 PM
How can the Sigma server, which typically run as a service, be configured to run as an application?
Satchwell BAS & Sigma
  • Sigma 4.05 and above
  • Windows 7
  • Windows 2008 server
  • Windows XP
  • Windows 2003 server
Certain operating systems, such as Windows 7 and Windows 2008 Server, do not support running the Sigma server as a service. To enable the ModBMS DDE connection on these platforms, the Sigma server must be run as an application.
To switch between running the Sigma server as a service or as an application, use the following commands via the Windows Start > Run dialog:
  • To run Sigma server as an application (after it has been installed as a service):
    "C:\Sigma\bin\SigmaSvr.exe" /regserver
  • To revert and run Sigma server as a service (if it was previously set to run as an application):
    "C:\Sigma\bin\SigmaSvr.exe" /service
How to Verify the Current Mode:
  • Open Services on the computer.
  • If SigmaSvr is not listed, the server is running as an application.
  • If SigmaSvr is listed, the server is running as a service.
  • Satchwell BAS & Sigma
Tags (2)
  • 4600
  • CraigEllis25
