Replacement I/NET Controller NICAD Battery info
  • Replacement I/NET Controller NICAD Battery info
‎2018-09-10 02:12 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:03 AM
Replacement I/NET Controller NICAD Battery info., I/Net Batteries
TAC INET
All I/NET controllers
Controller battery has failed, because the battery on the controller is over 5 years old
  1. The 3 pin version Battery is used for the NPR2000 and the DPU48K (MIP Board) -- part number 3/V80H-SLF (Note this battery has to be order from an outside Vendor and not Schneider Electric).
    Click here to view a PDF on this part.
  2. The 7910, 7920, 7930 7780 & 7940 use the 2 pin version -- part number 3/V80H-LPC (Note this battery has to be ordered from an outside Vendor and not Schneider Electric).
  3. The battery used on the 7700, 7716, 7718, 7728, 7720, 7928, 7793, 7798B, & 7798C (and like controllers) is the Dallas/INET part number 801288-07. This also can be ordered from the Rockford order entry using 01-2100-545 (Old CSI P/N 801288-07). This battery also has an outside Vendor source from Power-Sonic P/N - PCBM-3.6
  4. For battery testing process see How to test the NiCAD Battery on a Controller
  • TAC INET
Tags (3)
  • 5753
  • CraigEllis19
  • numbers
100% helpful (1/1)
