Remote Client with I/O in the Workstation Type of the I/O Server 2.4 and later
  • Remote Client with I/O in the Workstation Type of the I/O Server 2.4 and later
  • sesa139513
    sesa139513
‎2018-09-07 07:06 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-11-17 11:06 AM
What is Remote Client with I/O in the Workstation Type in the I/O Server?
TAC INET
I/Net Seven version 2.4x with need for Remote Client configuration using a Remote SQL Server.
Equalization, FileMaster, File Master, Equalized Client, Remote Client, Equalize, FM, EQ, RC, MSDE, Express, Full SQL, SQL, TCP/IP, Connection
Remote Client changes with I/Net Seven version 2.4x
The new option of Remote Client with I/O for the Workstation Type begins with 2.4x version of I/Net Seven. This option is for a SQL Server which is not located on the Filemaster or Standalone but rather a separate Server. The Remote Client with I/O must be running for other standard Remote Clients to get the features such as AMT, Trends, and Network Functions. Network Functions can be found in I/Net on the pull down menu Edit/Host Computer/Network Functions.
The configuration is in the I/O Server under the current profile and can be found in the Workstation Options.
HINT:
Exit the I/O Server (and I/net) and select Start/Programs/I/Net/I/Net Configuration to be able to setup the Remote Client. Remote Client is not show unless you exit I/O Server.
Clicking the link below will open a pdf document which will show how the communication should be setup if selecting Remote Client with I/O.
I/Net version 2.4x Remote Client with I/O
Clicking the link below will open a pdf document which will show how the communication should be setup if selecting Filemaster, Equalized Client, or Remote Client.
I/Net version 2.4x Filemaster, Equalized Client, or Remote Client
Suggestions for further info:
To install the SQL, go to Installing I/NET Seven on a 64-bit operating system. For more on how to set up that Remote Client with I/O to use that SQL database, see Unable to connect Remote Client to Standalone Server.
  • TAC INET
Tags (4)
  • 3965
  • Equalized Client
  • File Master
  • Remote Client
