Remote Client Configuration Issues I/Net 2.31 and prior
  • Remote Client Configuration Issues I/Net 2.31 and prior
  • sesa139513
    sesa139513
‎2018-09-07 06:26 AM
Remote Client Configuration Issues I.Net 2.31 and prior
TAC INET
I/Net Seven version 2.xx with need for Remote Client configuration.
Equalization, FileMaster, File Master, Equalized Client, Remote Client, Equalize, FM, EQ, RC, MSDE, Express, Full SQL, SQL, TCP/IP, Connection
Remote Client changes with I/Net Seven version 2.21 to 2.31 release.
There are two different configurations for the Remote Client setup in I/Net Seven. Clicking the links below will open a PDF document which will show how the communication should be setup.
This configuration is in the I/O Server under the current profile and can be found in the Workstation Options.
*IP Addresses are for demonstration purposes only.
  • TAC INET
Tags (4)
  • 3943
  • Equalized Client
  • File Master
  • Remote Client
