MSMQ errors and Continuum fails to start
  • MSMQ errors and Continuum fails to start
  • Carl_Slack
    Carl_Slack
‎2018-09-07 03:17 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-11-18 03:00 PM
Error displayed:
Enhanced Alarm Delivery
"There appears to be a problem with the configuration of this system. Please check to make sure that you have correctly installed MSMQ. The system will now shutdown."Enhanced Alarm Delivery Error - MSMQ.jpg
Andover Continuum
Windows OS
The issue is that MSMQ is not installed on the machine or the installation is corrupted. MSMQ is a windows component that needs to be installed for enhanced alarm delivery.
  1. Install MSMQ from the Windows Control Panel > Add/Remove programs or Add/Remove Windows Components
  2. Reinstall Continuum
NOTE: There have been instances where uninstalling MSMQ from Add/Remove Windows Components then allowing Continuum to install MSMQ resulted in a successful installation of the MSMQ.
  • 3985
