MSMQ error message: "Appears to be a problem with configuration of system please check to make sure you have MSMQ correctly installed"
  • MSMQ error message: "Appears to be a problem with configuration of system please check to make sure you have MSMQ correctly i...
  • sesa116827
    sesa116827
‎2018-09-06 02:13 PM
Continuum 1.9X
Windows XP and 2003 Server
Message Queuing Not installed
  1. Open Control Panel
  2. Select Add and Remove Programs
  3. Select Add / Remove Windows Components
  4. Select Message Queuing
  5. Restart System and test.
  • 4437
