Configure a Niagara G3 ENC serial port for dialup modem
  • Configure a Niagara G3 ENC serial port for dialup modem
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 01:33 PM
How to configure a Niagara G3 ENC serial port for dialup modem.
TAC IA Series
  • ENC-520-2
  • ENC-410-1
Dialup modem setup.
  1. In the Station, under Platform Services, go to the SerialPortService
  2. In the Port Config field, change the setting to Com1_232_com2_modem. Save this setting.
  3. Now, go to the Platform of the ENC, and go to Dialup Configuration
  4. The Init String should look something like this:
    ATE0S0=0Q0V1X4&D2&K3\N3%C2&C1&Q5W2
    Change the 0 just after the "=" sign to a 2.  This will tell the modem to answer on the second ring.
  5. Make sure that the Port field says COM2
  6. Check the Enabled box next to Listen for Calls
  7. In the Local IP Address field, type in the IP address of the ENC
  8. In the Remote IP Address field, type in an unused IP address on the same subnet as the ENC.
  9. Type in a User Name (eg. invensys)
  10. Type in a password (eg. niagara)
  11. Save your changes, then click the Start button at the bottom of the page.  This will start up the dialup daemon.
  12. Re-boot the station in Station Director.
  • TAC IA Series
  • 5660
